Synthetic, By-Pass Filters= Snake Oil???
Old 12-13-2006 | 07:28 PM
SupaDupa's Avatar
Originally Posted by bluebull
Hey, it's the one greatest conversation starter at every campground I stop at. No one ever asks if I have a by-pass system.
Instead they ask, " How's your Edit Buahahahahah
Old 12-14-2006 | 09:41 AM
ironside's Avatar
so will someone explain what the by pass system is.
Old 12-14-2006 | 09:57 AM
johnh's Avatar
here you go
http://www.oilguard.com/
Old 12-14-2006 | 03:36 PM
CD in NM's Avatar
I am using the Valvoline oil as recommended by the manufacturer, except I do my changes at 3500 miles. Almost all of the 06 owners seem to be complaining about how quick the oil becomes sooty.
Just in case those free range fed, non-genetically modified dinosaurs happened to become extinct due to a previous civilizations environmental mistakes, 'cause you don't know about how the plants they ate might have been modified to become undigestable proteins greater than 2-microns.
Seriously, I'm adding an oil bypass filtration system to cover all the bases. Taking the oil down to 2-microns of clean means less abrasives in the lubrication. After all, it is the abrasives that cause ring failures, seat failures, etc.
CD
Old 12-14-2006 | 08:04 PM
C Schomer's Avatar
I've had an Oilguard since 2000, when they had a 1/2 price sale. Otherwise I'd have gotten a TP bypass to save some $$$. I have put as much as 25k miles on syn oil, without a bypass element change and the oil analysis was still good and the soot level stayed WAY low. I started checking pressure drop across the fullflow filter to try to come up with a change plan for it. A new fullflow has about 1.5 psi DP and it only went up to 2.5 psi DP, at 10k miles. I will go 15k, next time and check it then. A bypass is a win/win/win deal. What you spend on a bypass pays back in reduction of fullflow filters, you clean the oil much better and get longer oil life. If you use a bypass to it's full advantage it more than pays for itself, especially with syn oil. A TP bypass works great but the rolls plug up faster - they don't have much face area. Craig
JeepManIowa
11-07-2007 07:29 AM
infidel
07-28-2007 01:43 PM
upjeeper
06-17-2007 04:05 PM
Johnny RAM
05-08-2004 12:30 AM
Stevie G
12-06-2002 09:42 PM
Quick Reply: Synthetic, By-Pass Filters= Snake Oil???
