Synthetic oil quesion.
I've got a local vendor and am seriously considering switching to amsoil synthetic motor oil. My ? is how many miles do you guys go (mostly unloaded in my case) before you change your oil. I've been changing Rotela T every 5,000 miles.
thanks for the help.
Jamie
Jamie
if you are going to run AMSOIL without the bypass system then change it at the normal interval at a minimum. You can extend out some if you want to. Also make sure you use the AMSOIL oil filters because they will make a difference in how they ckean the oil over regular oil filters
Roadstar
01-14-2010 03:50 PM
rico334
01-03-2005 08:10 AM
snice
14
04-29-2003 08:41 PM
