Suggestion on Low Diff Levels
Just a suggestion on 03s that are being bought with low diff fluid levels...give NHTSA a call and file a report with them. D-C is kind enough to give you the number in the back of the owner's manual.<br><br>Mine was 36 oz low in the rear and 14 oz low in the front. Thankfully I had only approx. 340 miles on it when it was suggested that I look at it by a guy in my 4x4 club. I called NHTSA that night. If they have enough reports, maybe D-C would actually start addressing it.<br><br>What I can't believe is that it should be a known problem to D-C, and they allowed me to drive off the lot with the low diff levels. Safety-wise, you really don't want crap to stop turning at high speeds. Just imagine if you had 13k worth of trailer.
Re:Suggestion on Low Diff Levels
Well let me ask you, i`ve seen different threads on this problem. i just checked the levels on my `03.front is level to bottom of drain plub, back is 3/4" low. first , what is the level SUPPOSED tobe?, and 2nd, wut do i put in there to TOP IT OFF?<br><br><br><br>Buddy
Sounds like your front is alright. The rear, which in your case is the 11.5", should be 1/4" +/- 1/4" below the fill hole per the manual. That means right at the bottom of the fill hole is acceptable.<br><br>Per your manual, they recommend a GL-5 75W-90 synthetic. Either the Mopar stuff you get from the dealer or something like Mobil 1 would work just fine.
I took everyones advice when I received my new 2500 and checked the differentials. Couldn't even feel lube with my pinky finger so I took it to the dealer and I watched the mechanic pump fluid out of a barrel into the front and rear. Don't know exactly how much he put in, but he pumped that handle quite a few times. Had them check the transmission and it checked out ok. What a joke. I asked the service manager if they check during the PDI. He said they are supposed to, but haven't heard of anyone having any problems or finding theirs low. I directed him to this web site, he needs a little education!
It would be of interest to know if Bow Tie and Big G dealers are having the same Low Differential Lube Problems. Since AAM manufactures for those two and Dodge.
... and I watched the mechanic pump fluid out of a barrel into the front and rear.
afate45
06-07-2014 12:08 AM
banana
12-01-2009 11:44 PM
jmccart
06-20-2009 02:11 AM
