Stumbling problem
going back to d-max
.I think after doing a search I may have a fuel issue.I noticed my truck hesitating on takeoff .It will stumble leaving from a dead stop.The engine gets loud and the rpm increases very slightly.It sarted a while back and only did it every now and then.Its doing it more often now.It runs fine at wot.I checked for codes but have none.I did change the fuel flter a week ago.It will do it sitting still in park and idleing also.You can hear it start raddeling for a second or two.Any thoughts?
Hope this helps.
Thanks alot guys I thought there for a while you were ignoring me.
I Have the problem with or without my quad box.I guess I need to get it to the dealer.I just cant give up my truck for a week.I tried their free oil changes for a while but they keep it all day and I work out of mine.Thanks again.
![Big Grin](https://www.dieseltruckresource.com/forums/images/smilies/biggrin.gif)
mine would knock and shake at idle in a parking lot, then it progressed to doing it while driving. happened 3 times this weekend, then she wouldnt start. finally got it started and home, took 5 minutes to get it restarted, during the time it wouldnt start, i couldnt hear the LP running so I am replacing it with the BD kit. I will start on it tomorrow night. hopefully that is the problem, will keep posted.
Originally Posted by GrandpasRam
My trucks have all been bone stock except for guages and the Scotty III air intake. Obviously, Star did not want to replace the CP3 without being sure, so they ran a tank of fuel with 2-cycle oil added to it to see if the return valve was sticking, and as long as there was a high enough concentration of oil in the fuel, no stumbles occurred. For their purposes it proved the CP3 was defective, and they replaced it. Hope this all helps when you take it to the dealer.
MikeyB
Originally Posted by MikeyB
Hmmm. Maybe it's a good thing that I'm mixing TCW-3 in with Power Service Diesel Klean.
MikeyB
MikeyB
Chesapeake
11-29-2006 02:44 PM
tacohat
07-05-2006 12:31 PM
alltimelow1
04-06-2005 07:28 PM
