Stock Truck defueling hard!
Old 05-10-2021 | 03:23 PM
Smaay's Avatar
2005 Dodge Ram, truck is completely stock. This happens on days when its hot outside. havent noticed it on cold days. Normal cruising is fine, as soon as I roll into the throttle and make about 30psi, the truck just dies! the boost drops to 0 and there is no power. If i let off the throttle, give it a second, the truck recovers and cruises normally. If I let off quickly and then back on, there is still no power. I have to let off the gas completely for a few seconds, then roll into the throttle. I havent tried pulling a trailer but I can only imagine it will be worse as soon as the boost comes on.
WHATS WRONG??????
thanks
Old 05-10-2021 | 03:25 PM
Smaay's Avatar
sorry I forgot i posted about this last year, got no answers
https://www.dieseltruckresource.com/...1/#post3372639
Old 05-10-2021 | 04:51 PM
KBennett's Avatar
Is the truck throwing any codes?
Old 05-11-2021 | 01:19 PM
Green_Machine's Avatar
Sounds like maybe a bad wastegate/overboost.
Try disconnecting the wastegate solenoid. It should only give you 20psi or so then. This will check the mechanical operation.
Chay
Old 09-09-2021 | 02:38 PM
SolarExpress's Avatar
My 05 did this to me once. Embarrassing to admit but it turned out to be a really dirty air filter. Ran great as long as I kept my foot out of it. Tripped all over itself during hard acceleration. I usually change my air filter every other oil change. Apparently I forgot a couple of times.
rebel102285
09-24-2014 08:29 AM
bkrukow
32
07-17-2008 11:28 AM
inline6power
15
04-04-2007 02:49 AM
catnfool
12-20-2006 04:18 AM
napa 600
11-24-2005 10:55 AM
Quick Reply: Stock Truck defueling hard!
