stock clutch very notchy
03' completly stock with 65,000 miles and starting in 1st and second gear with no throtle the clutch is very jumpy and the same in reverse. No matter how much I baby the clutch it will always do it. its getting worse.
Any experience with this situation? What have you guys done about it.
3.73 gears, H2 wheels w/ 315's
What type of clutch should I go with. I'd like to add 60 hp some day and do alot of towing and stop and go traffic. The clutch does not slip when fully engaged, just from a dead stop. I did the H2 mod to bring the rpm's down and get 22 mpg hand calculated. I did a lot of looking through the threads be fore but didn't see this as an issue.
i know what you talk about notchy. I think you are saying like it jumps when you don't give it throttle: especially in reverse. Mine has done it for almost 70k miles and I have 105k on it now and still catches fine, shifts fine, no grind. I put amsoil in trans at 50 or 60k miles. I think it is all normal. And the truck has had 33's since new. I wouldn't worry about it. Just don't speed shift and use the throttle when taking off it should last.
I think i'll just ride it out for now since I have no sliping when fully engaged. I looked at south bends web site but no pricing. Any idea what they cost?
Um, call Peter at Southbend. At least get an idea of what you want/need now, and know what to expect WHEN it starts to go.
It is a wear item, and going with a South Bend is just plain smart. You'll find NO better service than what they will provide.
The part of the city I am in the speed limit is 40-55mph in places and I average 17-18 on the interstate at 67 I get about 20-21 which ain't bad. The truck is at 104k miles as well. Aaron
brianpgriset
08-02-2008 06:50 PM
Mark Hodowanec
02-20-2007 12:00 PM
Gypsyman
10-29-2004 12:11 PM
v12xke
05-15-2004 09:24 AM
