stock 06 boost pressures
Old 04-10-2009 | 10:03 PM
Timmer's Avatar
you guys ever seen over 35 pounds stock? im going to buy a boost pressure gauge and autometer makes a 0-35 pound, or 0-60 pound. id rather see the needle travel the hole gauge, insted of just half of it, so iv been thinking about the 35 pounder. if i ever up grade my turbo or start runnign more boost i can buy the 60 pounder for less than 50 bucks.
or, do we run more than 35 pounds stock?
Old 04-10-2009 | 10:05 PM
rich's Avatar
never seen over 29 on mine
Old 04-10-2009 | 11:01 PM
bob4x4's Avatar
All the 325 hp versions should be capable of peaking in the mid 30 range stock.
Old 04-11-2009 | 07:32 AM
rich's Avatar
well none of mine have stock, unstock different story, but if you will do something down the road then get the 60
Old 04-11-2009 | 07:44 AM
1985cucv's Avatar
60 lb all the way!!!!!1
Old 04-11-2009 | 10:01 AM
Billy Ram's Avatar
I would get the #60 gauge. Even if you only plan on making #30 boost you're at the top of the scale on a #35 gauge. When I was running the stock turbo I could see #40.
Billy
Old 04-11-2009 | 08:26 PM
MoparNut's Avatar
I've never been over 30 on mine. I had the same question as you, then I found the Isspro gauges, They have one that reads 0-40psi. Perfect!
Old 04-11-2009 | 09:35 PM
CamperAndy's Avatar
Get the 60 and mod the truck till you see it go all the way !!!!!!!!
Actually I can see 40 on mine when towing a grade so you would be better off with the 60.
Old 04-11-2009 | 10:15 PM
gafirefighter's Avatar
i've seen 40 on mine as well
Old 04-12-2009 | 11:31 AM
Devinraptor's Avatar
I have seen 39
Old 04-12-2009 | 11:45 AM
Dustybowls's Avatar
my 07 sees 40 also
Old 04-12-2009 | 01:40 PM
AH64ID's Avatar
Stock you should see about 32, before the WG opens.. then you will stay 28-30 on a light load and 30-32 on a heavy load.
With my WG off and stock fueling it takes work to see 35psi, so you should be fine with a 35psi gauge if that's what you want.
Anything over 33-34 would set an overboost code anyhow.
Old 04-13-2009 | 02:48 PM
rotax800's Avatar
The highest I have ever seem on mine was 36.
O.T
09-18-2007 12:50 PM
toupee
06-27-2007 04:19 PM
country4x4kid
03-06-2007 07:32 PM
Earthmover627
09-03-2006 10:08 PM
thumbs
08-03-2003 09:06 PM
Quick Reply: stock 06 boost pressures
