starting problem...please help!
Old 05-19-2008 | 07:24 PM
  #31
slowstang232's Avatar
would there be a problem if i would buy a OEM replacement?
Old 05-19-2008 | 07:33 PM
  #32
06RAM2500's Avatar
I believe DC went to the intake pumps cause they don't send metal and other junk into the CP3 when they fail. If you have the coin, spring for a FASS or Airdog. Supply a bit more fuel pressure and a bit more volume.
Old 05-19-2008 | 07:39 PM
  #33
Spooler's Avatar
Factory replacements are none.... They retrofited them to the in tank unit. They did my truck at 23,000 or so miles under warranty. The factory intank unit is up around $650-750 for the kit. Way more than a raptor 100. With money tight I would go with the raptor. Or, you can wait until it dies and pay that 200-300 dollars in a tow bill.
Old 05-19-2008 | 08:19 PM
  #34
where can i attach a mechanical fuel pressure gauge to check the pressure of the LP?
it looks like there is just all either hard lines or rubber lines
Old 05-19-2008 | 08:22 PM
  #35
06RAM2500's Avatar
Where the line bolts to the CP3. Need a banjo bolt to tap into it.
Old 05-19-2008 | 08:41 PM
  #36
sweet, thanks for the help guys!!!
can you get banjo bolts just at a hardware store?
Old 05-19-2008 | 10:21 PM
  #37
Spooler's Avatar
Maybe NAPA or www.dieselmanor.com (that's where I got mine)
Old 05-26-2008 | 06:02 PM
  #38
so last night the truck didnt start, so i had to replace the filter. today i checked the fuel pressure at the banjo bolt on the CP3 and its right at 9psi at idle
Old 05-26-2008 | 08:46 PM
  #39
Spooler's Avatar
That sounds normal. No codes showing up?
Old 05-27-2008 | 08:13 PM
  #40
no CEL, but this code does show...
P0480 Cooling Fan 1 Control Circuit/Open (Low Speed Fan Relay)
next step - injector return flow test?
Old 06-08-2008 | 12:44 PM
  #41
ok, so now its getting really bad and NEEDS to be fixed asap. i called a local diesel injection place...told him my situation, and he also thinks it's the injectors (and i made sure to not give any indication on the phone that i also thought it was an injector problem)
he said he would charge $200 for a leak down test, which includes taking every injector out and testing them individually.
should i just pay the $200 for a more "professional" test, or should i spend the $50 on the miller 9012 and 9011 tools to do the test myself?
Old 06-08-2008 | 01:38 PM
  #42
Spooler's Avatar
My suggestion is to run it until it quits if you don't have the money. Save that money for the day you will need it. You already know what it more than likely is, just save up for it.
Old 06-08-2008 | 07:44 PM
  #43
i have the money for some F1's, but i kinda would like to be 110% sure that my prolbem is my injectors before i dump almost $1,500 into some replacements.
Old 06-09-2008 | 12:00 AM
  #44
Spooler's Avatar
Actually it is a little more. 1200 for the tips and inspection, 100 dollars for all injectors that need rebuilding if they are rebuildable. So around 1800 bucks to do them all. Don will test them and see which one's are problems while he has them. Get ahold of Lloyd at midatlanticdiesel.com. Also, Be careful, only used his authorized dealers on his website list. A few folks have told some stories to unknowing people and didn't get what they paid for. Hope this helps.
Old 06-09-2008 | 04:06 PM
  #45
well i called the diesel injection place today to schedule an appointment, and i guess the guy i talked to on friday thought i had a 2nd gen 24v cummins. so they want $350 to do the test on my commonrail. needless to say, i just ordered the tools to do the test myself.
what are your thoughts/opinions on industrial injection injectors from performance diesel inc? they seem to have reasonably priced stock reman injectors
Quick Reply: starting problem...please help!
