Star Scan Features
Guest
Posts: n/a
Star Scan Features
I'm about 20 mins from going to the dealer and getting hooked up to the computer, I'm getting,,,
-High Idle through cruse (thanks to wagonfixin's mod
-Fog lamps on with high beams
-Horn honk off with door locks
-Trying to get trailer reverse lights off
-The dome light extender
-With any luck and perhaps a small bribe with the tec, DTL turned of
This is my first post, but I have been a long time reader, I love this Site
p.s All of this will be free, I just called up my salesman and told him I wanted some options enabled through the comp and it would only take 5 minutes, he was more than happy (as long as it was only 5 mins,) Wish me Luck I'll post how it went when I get home......
Guest
Posts: n/a
Well I'm back Here's How It Went
High Idle Worked Like A Charm
Horn Honk When Doors Locked Worked
I lowered my acc on to 45 secs
They would not turn off Day Time Running Lamps (Canada )
vzdude if you want them off you can change your country code to us and turn them off
also if anyone can help, he said their was no option for fog lamps on with brights? I had this on my 06, he wen back to talk to some one else and they said its a no no in Canada dang rules
also now my indicators flash very slow hahaha its odd but minor
i also got unlock all doors when the driver door was opened, nice feature
p.s it was all free and took 10 mins
guess ill have to order the fog kit from genos
I have an 2006 and was I told there is no setting in the Star Scan features that can be changed to allow you to have both on at the same time.
as far as the fog lights on with high beams tell them to un enable the fog lights.they will still work but the computer thinks they are not there so they wont kill the fogs when you hit the high beams.
krazykiller
i got this done on my truck!
krazykiller
no you do not need to go to the dealer to have them enabled just put in the switch and the fog lights and they will work.and they will stay on even with the brights on.
The Daytime running lights and foglights with highbeams can be enabled or disabled with a bullydog downloader with version 2.4.1. My signal lights also blink slow after changing some headlight options, but correct themselves after a few starts, generally within a few hours. Hope that helps, maybe you know someone with a bullydog that can do it for you.
Also, I did the high idle mod as per wagonfixin's directions, got the pin from cummins, and grounded. My high idle won't work still when enabled on the bullydog (it says auto only). Is there a flash or something for the computer that makes it work that the dealer has to do?
Why would they care if the fog's are on with the bright's? You only have your brights on when your out by yourself. They would go off when you dim your lights for oncoming traffic--right??
I have a Britebox on my 03 to keep my fog's and dim's on when I hit the bright's.
Randy
Randy
