Stalled twice when coming to a stop.
Old 10-29-2006 | 05:41 PM
Hounddog's Avatar
Was pulling horses and twice when slowing down for a stop or turn truck stalled.Restarted easily and set check engine light.Code PO341. I do have a Rokktech modified crank sensor.
Old 10-30-2006 | 12:01 AM
TexasCTD's Avatar
Can you reinstall the stocker crank sensor and see if it repeats?
Could it be the stock fuel pump about to croak?
Old 10-30-2006 | 01:54 AM
Hounddog's Avatar
Why do you say fuel pump?? Wife asked same question,LOL. I only have about 4k onj the Rokktech sensor but yes I put my old one away for safe keeping.Truck has only 23k on it.
Old 10-30-2006 | 02:43 AM
TexasCTD's Avatar
I just said fuel pump only because that seems to be the most common reason for these trucks to stop running momentarily, and then start them up and go on. That is, until the stock LP finally gives up altogether.
My stocker is running fine at 51K but I wouldn't be that surprized to see it die. If it does, I will not be getting the IN TANK pump. I will replace it with aftermarket as I plan to do so anyway to keep up with mods.
Old 10-30-2006 | 03:07 AM
Hounddog's Avatar
I read about the lift pumps but I do know two trucks (03s)that when traded in both had about 150k on them with stock lift pumps and no issues.In fact they had no issues with anything other then a couple of TSBs done early on.
Old 10-30-2006 | 03:21 AM
TexasCTD's Avatar
Oh, I am sure there are thousands of trucks out there on the stock lift pumps and run great at 100k +. I may be totally wrong about it being your problem. Your lift pump may be great, that was just a guess as a "possible" failure that made your truck stumble. It seems to be common.
A few months ago a friend and I installed a DiPricol Fuel pressure gauge on mine so I could monitor it since it has become such a common failure.
Hopefully somebody with more knowledge can chime in and help you diagnose it. Good luck with it and keep us posted.
Old 11-01-2006 | 01:34 AM
Hounddog's Avatar
Did this thread dissappear?
Old 11-01-2006 | 02:44 AM
TexasCTD's Avatar
I was wondering the same thing.
I wish somebody else could jump in and try to take a stab at your problem. Any updates?
Old 11-01-2006 | 03:23 AM
Dodgezilla's Avatar
Have you checked your fuel filter or air filter? Either one could cause your issue if they were too dirty. I would suspect the fuel filter first. On my 03 I was only good for about 10,000 miles on my fuel and air filters before I started noticing problems from them being dirty...
Old 11-01-2006 | 05:26 AM
Hounddog's Avatar
Its fresh. What I meant by thread disappear was it showed up when I logged in for hoyrs as my last post about it being minutes old BUT it was not showing up on the forum.So I adeed did it disappear and it came back into the forum.Strange.
woodrep
01-20-2010 10:43 PM
Gbuilders
05-08-2007 02:20 PM
jsflagstad
02-16-2007 10:40 PM
slivertruck
25
11-08-2006 08:35 PM
royta
11-06-2006 08:19 AM
Quick Reply: Stalled twice when coming to a stop.
