Squeak, squeak, squeak ?
I'm getting a squeak, squeak, squeak noise under my truck at low speed. I can hear it with the windows down, pulling into the garage. It seems louder in reverse and not as bad when out of gear, forward or backward. Using the breaks doesn't have any effect on the noise. Any ideas?
Same here...just started last week. My brakes are grinding..just replaced driveshaft U-joints and driver side front wheel U-joints as well and upper and lower ball joints Been an expensive month for me! Looks like im getting under there again for the next set of U-joints.....
so i read this thread and replaced my rear drive line u joints. and no luck still have a back up only squeak. do i need to look at the axle u joints. i just replaces the passenger axle u joint. the truck has 134k on the odometer. do the front drivelines cause this squeak?
Guys... do yourselves and your trucks a favor and replace the inferior factory stuff with something like this..
http://www.spicerparts.com/driveshaft/automotive.asp,
There may be others that are equally as good, I know these work..
