Speedometer is off
Speedometer is off
Once I put my new tires on I updated the size with the programmer. Problem is when I am going 72 the spedo reads 76. In the 60's it is around 3 off. What is the easiest fix to this? BTW the speed I am comparing is from my GPS
I watch wind blow...
just dial it in, It may take several tries, the smarty gives you all sorts of tire heights to choose from. not sure about the Hypertec. just move it up or down until it gets right.
Administrator/Jarhead
Larger size makes the speedo slower.
I took a tape measure and measured the tires while they were sitting, vice the measurement that the tire actually was.
Yep, and I still had to go smaller on tire size to get the speedo correct with the GPS. Ya just gotta play with it until you got it dialed in.
05 CTD2500
04-09-2008 06:39 PM
tony597fitter
06-16-2007 10:35 PM
