speedo is off...how fast am i going
Find your self a stop watch or digital clock. Then find yourself a straight and clear stretch of highway that has a few miles posted. Get up to speed and set your Odometer and cruise control to what should be 60MPH. Then as you pass the first mile post note the time or start the stop watch. Cruise the mile to the next mile post with out adjusting the speed and note the time or stop the stop watch. You should complete a mile in 60 seconds at stock tires and every second above or below that will give you how fast or slow the Odometer is now. No need for a GPS or
Flashy Radar Machine, just some simple math problems.
For Example: I set my cruise to 60MPH. As I pass the 1st mile post I click my stop watch on. Then as I passed the 2nd Mile post I click the stop watch off. I noticed that I completed the mile with the cruise control set to 60MPH in under 55 seconds. So that means I am 5 miles faster and that means at 60MPH on the Odometer I am actually going 65MPH. Or you could use the math problem (1 mile / 60 seconds = 60 miles / 3600 seconds).
Shawn
Shawn
with 35" tires and 3.73 at 65mph I was running around 1750rpm, was to pay $60 at service shop to recalibrate speedo, I had to explain to the service guy how to do it. Service manager, said no charge and thanked me for showing them how to do it! So much for "chrysler trained technicians"!!
I found that the faster you go...the more the speedo is off.
I have 37's and the dealer attempted to calibrate the speedo for me but couldnt.
My speedo reads Im going 100km/ my gps says 114km. But at lower speeds like 50km the gps reads 55km.
I dont think you are cute and blonde haha so Id get it fixed before you end up with a ticket. Fortunately for me, a smile and a dumbfound look to the cop got me away with no ticket lol
That's correct; as Triplenickel stated, using his 10% error, if you're showing 35 mph on your speedometer, you're really going about 38.5 mph. If you're showing 70 mph on your speedometer, you're really going about 77 mph. If you're showing 90 mph on your speedometer, you're really going about 99 mph.
Greg
Greg
It needs to be set in the ABS brake section of the scan tool. Best bet is get the # of revolutions per mile from the tire manufacturer for the size and model of tire you have. This is the MOST accurate. Try not to use the default tire sizes DC gives you to choose from in the scan tool.
And yes it goes by percentage not a MPH number. So as speed increase so does the number.
EdmontonCanada
37
12-09-2009 03:18 AM
