snaped a back drive shaft
Old 09-27-2010 | 01:11 PM
loya 3500's Avatar
Question snaped a back drive shaft
OK guys i was playing last night and well. i loaded the truck up with 26lbs of boost let it go and it went down hill fast from there...
after the carrier baring on the second part.. it snaped off all 4 arms on the Ujoint that conects to the back axle to that part of the drive shaft..
im going to replace the back drive shaft but i wanted to know if i should upgrade or go to a one pice drive shaft.?.
i have seen those but i dont know if there any better then the 2 pice i have now..
id like to know what yall think... or should i just replace it back with what i had that is a stock drive shaft....
Old 09-27-2010 | 01:47 PM
klx650a2's Avatar
If you're going to be doing boosted launches, I'd say spend as much as you can.
26 pounds of boost? Wow.
Old 09-27-2010 | 02:00 PM
loya 3500's Avatar
it will spike 30lbs of boost if i stomp on it... any one have any suggtestions on what to go with....
Old 09-27-2010 | 02:54 PM
cbrahs's Avatar
you won't be able to buy just the back 1/2 from dodge. only way to do that is to take what you have left to a driveshaft shop and have them rebuild it.
go 1 piece either that or step down a few psi when playing on boosted launches lol
Old 09-27-2010 | 04:14 PM
loya 3500's Avatar
i think im just going to buy the back shaft from a parts shop that is by me he has a wrecked dodge and put new Ujoints and go easy on the truck.
the old shaft is bent bad from hiting the ground and it did fall out from under the truck... so i putt it in 4 high and drorve it home i was only 15mi from home...
Old 09-27-2010 | 04:17 PM
loya 3500's Avatar
turbo
I am still runing a stock turbo
Old 09-27-2010 | 08:38 PM
cbrahs's Avatar
better just get the entire shaft. the back 1/2 is balanced to the front 1/2 and $5 says you get a vibration. Just my .02
Old 09-27-2010 | 09:28 PM
Mr Jerry's Avatar
To bad it didnt do more damage.
Old 09-27-2010 | 09:55 PM
Tacomaman87's Avatar
wow someone's jealous
Old 09-28-2010 | 11:18 AM
loya 3500's Avatar
i think someone is a little jealous to WOW i would never wish that on any dodge person.. Mr jerry.. i just wish it would have put all that power on the ground lol it would have been sweet.. OH and i bought both of the back shafts to geather so i dont have any probs with just one form the other truck..
thanks every one for any info
Jay123
12-28-2014 02:29 PM
Det 1
17
12-22-2009 08:32 AM
4x4dually
01-05-2007 01:07 PM
signature600
10-05-2005 01:43 PM
JoshPeters
04-03-2005 08:13 AM
Quick Reply: snaped a back drive shaft
