smokin at startup
Old 11-26-2005 | 10:25 PM
moltred's Avatar
Unhappy smokin at startup
my 04.5 blows blue (yes blue) smoke when started cold.the longer it sits and the colder it is outside the worse it is.truck has been doing this since about 18000 miles.
Old 11-26-2005 | 10:44 PM
Geico266's Avatar
Normal, but it's time to plug it in below 40F.
Old 11-26-2005 | 11:19 PM
J BODY's Avatar
Glad to hear everything is A-OK!!
Old 11-27-2005 | 01:33 AM
phox_mulder's Avatar
Yes, normal.
Diesel Fuel is in fact oil, hence the blue tint.
Walk into the cloud and sniff (gently), you'll be able to tell if it's oil or Diesel.
Diesel will make you respect those in boot camp, and the tear gas shed.
phox
Old 11-27-2005 | 02:49 AM
Sailpipes's Avatar
Tell your dealer about it. There is a reflash for the ECM to help correct that. The white smoke doesn't really hurt anything but the reflash helps improve MPG and is supposed to help the accuracy of the MPG calculation on the overhead display. Mine didn't get any more accurate, now it's about 1 mpg high instead of being .5-1 mpg low. It did help increase fuel economy and I didn't get as much white smoke on start-up on cold mornings though. Someone correct me if I'm wrong but the reflash is 18-037-04 I believe.
Old 11-27-2005 | 07:27 AM
mikmaze's Avatar
thats the right flash, however I read around here somewhere that there is a newer version of the same flash out there??? that doesn't make sense to me but I read it on this forum so its gotta be true
crobtex
01-26-2004 05:35 PM
hellotbone
26
08-01-2003 08:50 AM
SjLingenfelter
04-09-2003 04:34 PM
94dsl4x4
03-21-2003 02:58 PM
powerwagon440
03-19-2003 03:14 PM
Quick Reply: smokin at startup
