slight surging
slight surging
I was driving back from minnesota last night, doin about 70-75 after about an right about the iowa border I start noticing a slight surging around 74 MPH. it was REALLY slight, but enough that my wife noticed it too.
I was mixing between 4 HI (going about 60mph) and 2, as the roads had some iffy spots left over from the storm. I had filled up before we left, and added some PS.
If I was going by the instrument panel, I wouldn't have believed the surge was happening, the RPM's were constant, everything was holding steady.
is there something I should be checking? I don't know where to start.
wasnt in cruise, I avoid that when the snow flies. could have been binding, it was changing from ice and snow to pavement quite frequently.
That was my idea when I asked if it only happens in 4x4. If it doesn't do it in 2 wheel, it's probably binding. You don't have different tires on front and rear or anything like that do you? Different loads, pressures, weight?
you guys might be right, all 4 tires are the same, tire pressure was the same. not much weight in the bed, just a couple hundred pounds.
Josh1979
18
06-03-2012 04:06 PM
leonesm
04-29-2009 03:37 PM
sallyman1
01-27-2009 10:33 AM
Common
09-19-2006 05:27 PM
