slight rattle when taking off from a complete start
Old 10-17-2008 | 03:04 AM
cody323's Avatar
i have a 03 6-speed and when i take off from a start in 2 gear i notice a rattle coming from underneath. the rattle quickly go's away with acceleration. i have been told that the most likely issue is with one or more of my u-joints. does anyone have more info on this?
2003 QC 305/555 4x4 long bed
Old 10-17-2008 | 05:52 AM
MikeyB's Avatar
I get a little bit of timing rattle when the engine is loaded down and some gear rattle when taking off in 2nd gear. Does it rattle in 1st gear?
MikeyB
Old 10-17-2008 | 10:12 AM
98whitelightnin's Avatar
My 03 started to rattle when taking off in 2nd and had a little rough idle when i needed an injector replaced.
Old 10-17-2008 | 10:20 AM
purduepurdy's Avatar
Have a two piece rear shaft? I had a dakota with a two piece shaft and the carrier bearing and mount were loose and would rattle under accleration like what you are describing. Granted I think our trucks have a bit more torque than a mighty 3.9 V6.
Old 10-17-2008 | 10:31 AM
I forgot to mention that when i took mine to the dealer and told the service guy that it was rattling and i thought it was an injector he said that he thought it was a rear u-joint. In his defence he said he had'nt been a dodge tech too long and that he was a chevy d-max tech for 8 years.
Old 10-17-2008 | 06:03 PM
cody323's Avatar
thanks for the info. it does not do it in 1st gear. and the engine runs like a top.
Old 10-18-2008 | 01:39 PM
1993rollincoal's Avatar
if your u joints are tight and your steady bearing is good it might be driveline angle problems. There is a TSB out from dodge.
Cnt4
06-23-2013 07:46 AM
sallyman1
01-27-2009 10:33 AM
Common
09-19-2006 05:27 PM
Quick Reply: slight rattle when taking off from a complete start
