simple question?
Old 05-25-2009 | 12:00 AM
choppers555's Avatar
simple question?
when your transmission goes into lock up, Should it LOCK up Hard? seems to really slam into lock up. is this normal?
Old 05-25-2009 | 09:33 AM
.boB's Avatar
No, that's not normal.
Old 05-25-2009 | 01:31 PM
TAS05CTD610's Avatar
So how hard? I see you have a ATS stage # upgrade, and I have heard of others saying the lock up is a bit harsher than stock with a aftermarket trans upgrade. I don't know what harsh it, but most say you have to let off the go pedal when it locks and you can learn to drive with it, a bit better. Check out one of those threads
Old 05-25-2009 | 02:02 PM
Ace's Avatar
Ace
Originally Posted by TAS05CTD610
...you have to let off the go pedal when it locks and you can learn to drive with it, a bit better.
That's how I run mine in tow/haul mode, stock. You basically shift it with the accelerator once you learn the shift points, smooth as silk.
jumpinj
17
12-15-2005 10:38 PM
HorseHauler
11-07-2005 09:32 PM
ExactOh
05-04-2005 10:04 PM
dieselcrazy
01-05-2004 03:39 PM
Quick Reply: simple question?
