silly question 5th or 6th
Old 04-23-2007 | 03:01 PM
ZARRTX's Avatar
Any pros and cons on A 2003 3500 manual tranny, having a 5 speed or a 6 speed with 3.75 gear. What does the 6 speed give more of??/ Thanks I said silly question. Thanks for humoring me>.
Old 04-23-2007 | 03:54 PM
dodgezilla04's Avatar
the final drive ratio is the same between the 5 & 6 speeds. the benefit is the gear ratios are space closer together, giving you less of an rpm drop between gears. keeps the engine alittle better in the powerband.
Old 04-23-2007 | 04:21 PM
ZARRTX's Avatar
thanks for the reply, I will shoot for the 305/555 6 speed, then the 5 speed. thanks
Old 04-23-2007 | 10:04 PM
C Schomer's Avatar
You'll love the 6sp if you haul much weight and it's a stronger trans than the 5sp. Plus the 6sp will be with a HO instead of a SO. Craig
Stealth Mode
11-20-2005 01:57 PM
Buckshotram
11-01-2005 11:28 PM
GCSS
05-12-2005 10:41 AM
Mark Hodowanec
10-27-2004 10:37 AM
More Power
01-25-2004 06:44 PM
Quick Reply: silly question 5th or 6th
