Silencer Ring?
Silencer Ring?
I've heard alot about guys pulling off their silencer rings off their turbos. I kind of like that turbo sound so i decided to go for it. I took my intake tube off and didn't see what was desrcibed in past forums. I didnt see any plastic/rubber rings. Does anyone have a picture they could show me or any instructions on how to find this silencer ring? this is on a 2004.5 high output engine.
DTR's Self Appointed Beer Advisor
here are a few pictures that will help you see what we are talking about.
silencer ring in front of the turbo
silencer ring and snap ring removed
trubo without the silencer ring
britt
britt
Originally posted by procrastinator
What and where is the intake tube baffle? What is it supposed to do?
James
James
britt
From: From Texas; Staioned in WA; Transplanted to AZ
To get it out, you have to pry the top off with a screw driver... you may be a lil on edge to do it because of the sound it makes, but it's glued on so it's just that seperating. Just pry the top off, pull the baffles out and then superglue the top back on.
I've got some pix in my gallery I'm putting in now... so once they're approved, they'll be there for you to see.
Oh, and I also removed the plastic insert in the lower elbow into the Turbo.
Hey guys thanks for the response i guess i didnt know what i was looking for.
Bubba_CTD, what do i have to super glue?
One more question, if i wanted to put the ring back in will i have to glue it back in?
The super glue is for if you remove the baffles out of the stock torque tube... it's held together with some kind of glue and it doesn't snap into place like other things might. So once it's pried apart and the baffles slide out, the tube needs to be glued together.
As for the ring... it's even easier to put it in. Just remember to grab two really small flatheads to take it out. Almost as small as jewelers, but not that small since those are too weak. As you can see by the pic of the ring above, pry one screwdiver under the lip at one end of the ring and pry it up just enough to stick the other screwdriver under it. Then pry that up and stick the first in and work it around... I don't think you even need to work it but the first 1/4 of it and at around the halfway point, you can just pull it out.
