Side swiped a snow bank HARD!! plz help
Old 11-21-2010 | 11:40 PM
rolling18's Avatar
Exclamation Side swiped a snow bank HARD!! plz help
GoT carried away last night and slammed sideways into a hard snow bank and Effed up the truck!!! (all panels on driver side smashed in)
So now the transfer case is stuck in 4wd LO!! (electric switch) nothing happens when i switch to 2 wd, light stays on steady regardless, tried backing up nuetral, forward.. nothing.. various combinations,
I have to get this fixed b4 work tues.!! i dont want to tear up my tires/ drive components!!
please save me from the cost of Dealer diagnostic ans service!!!!
thanx
Old 11-22-2010 | 06:32 AM
JRD's Avatar
JRD
Maybe try resetting it with the little hole next to the selector? But then it might get stuck in neutral then your truck really wont go anywhere. But then again it may work?
Old 11-22-2010 | 08:27 AM
Grit Dog's Avatar
Unless you whacked it hard enough to break something in the drivetrain or bent the frame, it's probably just packed full of snow, now ice and won't switch over. Is the undercarriage packed full of snow? I've had vehicles that you couldn't shift back to park or reverse because of so much snow in the undercarriage.
Old 11-22-2010 | 08:37 AM
mq105's Avatar
Also check the connector/wiring from the switch to the TC. You may have torn something loose in the circuit.
Old 11-22-2010 | 12:43 PM
rolling18's Avatar
gave that a try, but found no button in the hole using a long micro screw driver just went all the way in (when i key on, all the lights come on including the red N, then go out leaving the 4 lo only on..
Im back home now, no snow under the truck, dried out, warm again, looks good
all wires/ plugs i could see looked good and tight, attached vacume hose good, even tried tapping the solonoid as i found in a search .. no luck.. uhh this gonna cost me a $$$ at the dealer..
Old 11-22-2010 | 01:32 PM
dslpwr81's Avatar
Ummm....turn it in to your insurence. Pay the deductable and have it all fixed. Don't pay the dealer. I'm sure the dealer price will be the price of your deductable. Good luck.
Old 11-22-2010 | 05:16 PM
rolling18's Avatar
thanks! thats what I will end up doing,
after further research and a diagnostic with the tec computer.. it appears something was damaged INSIDE the xfer case beyond electronics,
the tech could not get it into any other setting manually.
total estimate for the body repairs is 6.5K plus whatever the xfer case work will be... so thats that
on the good side.. my truck will look brand- new (on one whole side) including a rear bumper the paint previouly had lots of scratches and dings.
now it will look half new! instead of all- very used...
thanks for all your guys help and tried al suggestions!
roll on!
Old 11-24-2010 | 10:16 AM
HOBrian's Avatar
Ask body shop how much to fix it all and pay the difference for a new looking truck!
Old 11-24-2010 | 10:18 AM
Topper's Avatar
Must be another snowbank around...
Old 11-24-2010 | 12:39 PM
cdennyb's Avatar
From: In Oroville, Ca., same house for past 46 yrs!
We need pictures!
Old 11-24-2010 | 06:13 PM
Rednecktastic's Avatar
Complain till they paint the whole truck.
On a side note: you would have been better off spinning out .
Also, I thought snow was soft .
Old 11-24-2010 | 06:29 PM
07 ThunderRoad's Avatar
And I wasted all my time and energy keeping my truck clean and dent free. I should have bought a banged up truck and drove it into a snow pile, so I could get a new body an paint job. We have plenty of snow piles in the rust belt.
Old 11-24-2010 | 06:34 PM
bkrukow's Avatar
Only in movies. It may be soft sometimes but it gets hard enough after it sits a while that sometimes you can drive a vehicle on it. If its been moved at all with a blower or plow it can get hard as concrete.
Old 11-25-2010 | 05:20 PM
Dieseljunkie's Avatar
This is very true.. I just had some damage to my truck repaired.. I was backing into my driveway, and got too close to a snow burm that was on one side of the driveway, dented the lower rocker panel of the truck, from the bed all the way forward and on both doors. Snow that's been moved by a snowplow is generally hard as concrete.
Scott
Old 11-26-2010 | 01:01 PM
mtman86's Avatar
Big hail is worse......we had a good dose of it here last July. $120 mil + in various property/vehicle claims to my town. Nice short term stimulus package to the glass/autobody/roof companies.
Quick Reply: Side swiped a snow bank HARD!! plz help
