Should I use any Fuel Additives?
Old 03-10-2006, 04:21 PM
  #31
dhe9's Avatar
stanadyne
Originally Posted by Chip
I've been using Stanadyne Performance for 12 years now and it's the best additive out there. I've tried the Diesel Kleen and could see no results. Truck runs much quietier and milage is really good(18-22mpg on the highway) and much better acceleration.
Chip
so where does one buy stanadyne performance? don't think walmart sells it, what about kragen auto supply?
thanks
Old 03-10-2006, 07:08 PM
  #32
coobie's Avatar
thanks
I have never seen it at wally world.Try these two places Scheid diesel 1-800-669-1593 or diesel injection service 214-357-2771
Old 03-10-2006, 07:26 PM
  #33
Javahjoeo's Avatar
I am with Mad Duc. I use Power Service, and Marvel oil. 16 oz each in the tank before fillup. Maybe I don't need it, but a little Insurence for the long run. MPG is up over before I used the additives. I have 35600 mi. I do most in town driving. But on the road, I ride like on a cloud, smooooth as silk. javahjoeo from Kokomo
Old 03-10-2006, 08:49 PM
  #34
HdPower's Avatar
I am another believer in the PS / MM oil mix, it runs quieter, stronger and I get better fuel mileage.
Old 03-10-2006, 09:05 PM
  #35
texasredrider's Avatar
How many ounces of each do you guys run and how much is too much?
Old 03-10-2006, 09:48 PM
  #36
coobie's Avatar
I use about 8 oz per tank with the stanadyne PF.I also use primrose additive 405 summer 409 winter formula 12 oz bottle will treat 100 gals.coobie
Old 03-11-2006, 01:25 PM
  #37
dhe9's Avatar
so if i understand correctly i want to put about 12 oz PS and about 4 oz MM into the fuel tank? i guess my question is are my measurments correct and both into the fuel tank?
still learning about diesels.
thanks
david
socal
Old 03-11-2006, 01:34 PM
  #38
HdPower's Avatar
thanks
david
socal
You could go a little heavier on the MM oil ...kind of trial and error on what runs best in your truck but I use at least 16 oz of PS to 10-12 oz MM oil.
I have used it so often I don't even measure any more.
Old 03-11-2006, 02:10 PM
  #39
dhe9's Avatar
both right into the fuel tank? sounds easy.
Old 03-11-2006, 02:14 PM
  #40
HdPower's Avatar
Actually I pre-mix in an empty container then dump it in.
Old 03-12-2006, 12:16 PM
  #41
dhe9's Avatar
PS gray and MM oil
have 18,200 miles on my truck and have put PS Grey and MM oil in for the first time. drove about 25 miles and it seems as tho the truck is running better already. is this possible that i would notice the impovement already?
i put 16 oz PS grey and 4 oz of MM oil in to about 32 gallons of diesel.
just wondering if the truck could be running better already or is this just my imagination?
thanks,
david
socal
Old 03-12-2006, 01:22 PM
  #42
MikeyB's Avatar
I'm running 16oz of PS mixed with 8oz of TCW-3. I have used MMO in the mix but prefer TCW-3 since it's a little heavier lubricant and still burns clean.
MikeyB
Old 03-12-2006, 01:29 PM
  #43
Javahjoeo's Avatar
I use 16 oz's of Power Service and 16 oz's Marvel Oil, added just before fill up. Works for me. Your truck may be different. javahjoeo from Kokomo
Old 03-12-2006, 02:37 PM
  #44
Glock Guru's Avatar
Smile
Question? I see the benefits of using the Power Service, thats clear to me. All thou, were does the MMO come in to play. What does the MMO add to the mix that the PS doesen't. They seem to do the same thing (only based on info from manufacture) anyway. How long has this "brew" been in use by the diesel owners? Just wondering about long term useage (50-100k) of the two mixed together and there effects on the Cummins engine.
I ask all this because a have a new 06' 3500 4x4 CTD on order and @ 40K I want to get her started on the correct foot (or wheel).
Thanks, Troy
Old 03-12-2006, 05:44 PM
  #45
bekim's Avatar
Originally Posted by VikingDiesel
I found (2) Power Service Products:
1. Diesel Fuel
Link
2. Diesel Kleen
Link
They seem to be very similar, which one to get?
The white bottle has anti-gel, that's the difference. Is the temp below freezing where you live?
Mike
Quick Reply: Should I use any Fuel Additives?
