Should I use any Fuel Additives?
Old 03-05-2006, 03:15 PM
VikingDiesel's Avatar
A lot of people use different Diesel additives, such as:
STP
or others, I do have a brand new truck, so im wondering which one should I use, when to use it or should I even use any?
Old 03-05-2006, 03:22 PM
Timmay2's Avatar
Theres a Ford on the label, so Id stay away from it.
Old 03-05-2006, 03:50 PM
Willy91's Avatar
I would deffinently suggest running a fuel additive. It helps increase fuel lubricity and will help fuel systom parts last longer. There are many products out there such as Power service, standyne and so on. We've ran power service from day one.
Old 03-05-2006, 03:56 PM
Are they all pretty much the same? Can I use STP sometimes, Redline another time.....etc. Also, Does the Fuel tank need to full before I add the additive and Once I add it, does it need to be used at every fill up?
Old 03-05-2006, 03:58 PM
Also, which one do you use?? The injector cleaner, anti-gel, Cetane booster....etc?
Old 03-05-2006, 04:10 PM
Grim Reaper's Avatar
I use the Stanadyne Performance, seems to cover everything, though there are cheaper options. I purchased the case of 6 gallons from Diesel Injection Services and use it at every fill up, prior to filling.
http://www.dieselpage.com/additive.htm
Old 03-05-2006, 04:32 PM
abc4yew's Avatar
Not all diesel additives are the same. Some are little more than purified diesel. Look for an additive that actually says it does something other than just improve performance... as in prevent gelling to -x deg. adds 5% mileage or money back....adds 5 Cetane....etc. I use Howes in winter and truck is noticibly quieter and it flows freely at -25. In warmer weather I use Standyne performance and it keeps the internals quiet and definitely better acceleration and mileage. I don't have a fuel heater hooked up anymore and the truck starts within 2 seconds at -25 and no long smokey warmups. Diesel Kleen did nothing for me. ks
Old 03-05-2006, 04:37 PM
You think STP will be any good? Theres another brand I cant think of the name, its sold at all Truck stops and Truck stores, Kenworth, Peterbilt.....etc Its a long clear bottle and says Injector cleaners, Know what im talkin about?
Old 03-05-2006, 04:42 PM
Syndicate's Avatar
I ran a bottle of the STP stuff. I didnt like it at all. Truck didnt run any better and it didnt clean up anything. Next tank I ran Meaner Kleaner and it made a huge difference.
Old 03-05-2006, 08:44 PM
I found (2) Power Service Products:
1. Diesel Fuel
Link
2. Diesel Kleen
Link
They seem to be very similar, which one to get?
Old 03-05-2006, 08:52 PM
06dually's Avatar
I use standyne...it says pour in before you fillup. Ive noticed improvement in just two tankfulls.
Old 03-05-2006, 11:22 PM
DAYTRIPPER63's Avatar
With the direction diesel fuel is heading ( low sulfer fuel) I would say the most important thing to look for in an additive is to add LUBRICITY! I personally use Stanadyne but I am sure their are other good brands as well
Old 03-05-2006, 11:41 PM
redspider's Avatar
Howes they sell it at the cummins store
Old 03-06-2006, 12:23 AM
Which one?
Howes Meaner Power Klean
or
Diesel Treat
Howes Diesel Conditioner Plus Anti-Gel
Old 03-06-2006, 05:34 AM
MAD DUC's Avatar
I use the Power Service. The white bottle is their 'winter' formula. Silver bottle is for 'summer'. I mix either one with MMO(Marvel Mystery Oil), 12 ounces Power Service with 4 ounces MMO.
Quick Reply: Should I use any Fuel Additives?
