should I have my injectors cleaned? Help!!!
#32
Doesn't the axle pull out after the hub is all off. So they should not have touched the upper ball joints, right? I am in minnesota, the land of letting your truck idle to warm up. I dont think the dealer even did anything that you mentioned. They called dc and dc said to do clean them first before anything else.
#33
I have been having a similar problem with my 04 idling rough. It sounds like a gasser missing out on a cylinder. I can hear the miss until the exhaust gets too loud under acceleration. It seems to blow a little white smoke too. It got so bad at one point that the Service Engine Light came on. I didn't make it to the dealer before it went off tough. Just recently I had the code cleared and it came up as "Injector 2 Circuit Error" or something like that. Haven't found the problem yet. Any ideas?
Mark Hodowanec
12-28-2006 03:47 PM
