Short vid -10 below Exhaust lope
Old 01-16-2009, 03:44 PM
DBLR's Avatar
Being we set a record low of -31 below overnight I wanted to see how well my truck would start with out it being plugged in. I can say I only let the grid heater cycle one time and it stated like it normally does. I did notice that it ran some what ruff for about 15 seconds until the grid heater cycled on for the second time and after that it ran smooth at 1000 rpm's and no loping of any kind when I kicked it off high idle about 45 seconds after start up to see how it would idel at that cold temp.
Old 01-17-2009, 11:04 AM
shortie's Avatar
sounds like the 3 cylinder idle to me.
Old 01-17-2009, 11:08 AM
trik396's Avatar
Seriously??? Your 06' must be a totally different animal than my 05'.
Nothing about my -5 degree start was normal sounding... I run synthetic in the sump also...
Hmmm... anyway, I don't/won't do that again unless absolutely necessary.
Old 01-17-2009, 11:23 AM
DNRCustoms's Avatar
I am running the Amsoil Synthetic...15x40... I think I am gonna swith next time to 5x40.. Sounds like people are having good luck with that...
Took truck tp dealer and they are replacing the lift/transfer pump in tank... They said it is bad and thats why mine will stumble most times when I go to start it... We'll see!!
Old 01-17-2009, 12:11 PM
trik396's Avatar
How did they check? or are they just guessing?
Old 01-17-2009, 12:18 PM
DNRCustoms's Avatar
Well, they said they put the newest flash in and went they went to restart they duplicated the long crank/ stumble I have been complaining about and said they were able to test the system which pointed them to the lift/transfer pump... Personally I don't think it is the problem and not happy about the whole deal... But, I just want it fixed.... They are cool with a truck having mods and all and that is hard to find a dealer that doesn't have prejudice from the start... I trust the tech, he is real big into sled pulling and high performance stuff, he really seemed like he wanted to fix the problem for me... So hopefully they can get it worked out SOON!!
Old 01-17-2009, 04:16 PM
mini14's Avatar
mine does it too but it was only 9 degrees here sounded like it went inot 3cyl mode. but dont know if the 05's had that feature or just high idle, anyone know for sure ?
Old 01-19-2009, 07:16 AM
BMH95's Avatar
I'm not sure if it's an '05 thing. Mine definitely has a wathump, wathump, wathump type of bouncing lope to it when it starts cold. It normally only does it when it's near 0 F outside, unless it isn't plugged in.
Old 01-20-2009, 02:51 AM
05blkdlly's Avatar
This is the third winter with my truck . I run Rotella 5w 40 syn. oil and have never plugged my truck in . I drive it every day and it sits outside in the open . When it is below zero it starts a little harder than normal but idles smooth . My truck seems to run better in the cold than the summer heat .
NickBeek
07-18-2008 10:16 PM
rodeocowboy
Competition / Pulls / OffRoad
10-31-2007 08:33 PM
AprilzWarrior
Off Road / 4x4
06-22-2007 05:38 PM
Teddy Bear
05-30-2006 10:24 PM
lezmark7
06-07-2003 11:18 AM
Quick Reply: Short vid -10 below Exhaust lope
