Sea-Foam Harmful or Harmless
Old 01-23-2008, 11:44 PM
silver 60's Avatar
I would not put Seafoam in your tank if you dont use the truck often it contains alcohol and will condesate water with tempreture change. Ive been doing some reasearch on this my self and have noticed that Cummins uses Alcohol based products for all the diesel engines for flushing the injection system . So if they use it I would say go for it ,I did I just wouldnt over use a alcohol based cleaner all the time .
Old 01-24-2008, 06:21 AM
revolution_dsl's Avatar
i now use 2 stroke for lube and seafoam for cleansing.
Old 01-24-2008, 06:44 AM
paroxysym's Avatar
how much MMO would you use? a bottle on a tank of fuel?
Old 01-24-2008, 11:19 AM
none....ever, it takes lubricity away from fuel.
Old 01-24-2008, 12:21 PM
see here:
http://inchoate.harm.org/~halbritt/d...itive%20V3.pdf
Old 01-24-2008, 12:47 PM
SolarExpress's Avatar
I've used it twice just before a filter change. I followd the directions and drained the filter housing and added the can of Seafoam. Your supposed to let it idle through the system. No throttle. The CTD is smooth as glass while the SF is running through it then starts to run like normal once the diesel starts mixing with it. The truck ran incredibly smooth after that. There does not seem to be much benefit just pouring it in the tank. Too diluted.
Old 01-24-2008, 01:35 PM
paroxysym's Avatar
i gotta use something to clean the injectors out. she is running alittle rough/louder than normal. id like to get something to clean'er out. seems like i hear a different tick everyday.
Old 01-24-2008, 06:58 PM
Idaho Guy's Avatar
How Long to Idle
About how long does it take for the SF to be consumed if you fill the filter housing? 5 minutes? 30 minutes? Longer?
I used SF on my an old Chevy Vortec and it worked great. The truck smoked like a chimney, though. I suspect the same will be true for the CTD?
Old 01-25-2008, 11:48 AM
Probably about 5-10 minutes. The filter housing is only about 16 oz. And the CTD did not smoke like the gasser while the SF was running through it.
Old 01-25-2008, 02:03 PM
rip 112's Avatar
Exhaust smell any different?
supr
01-01-2011 11:38 PM
tcr1016
11-15-2010 04:51 PM
Boatnik
08-28-2009 03:21 AM
gerry
05-24-2006 11:19 PM
Crabjoe
03-13-2004 01:42 PM
Quick Reply: Sea-Foam Harmful or Harmless
