rpm's at idle???
rpm's at idle???
I have read some posts about trucks surging but none that really fit what mine did to me tonight. I went to a fast food joint to grab some burgers for me and the wife. Locked my truck up running in the parking lot. When I came back, as I started to open the door I heard my rpm's go up enough to really notice for about 3 seconds. I got in the truck and headed home. I was only maybe 2 miles from home. It did it again at a stop sign on the way. I would guess and only guess it went up to about 1400 rpm for 3 seconds both times. Truck has been running fine and did the rest of the way home too. No codes set off using the on off 3 times method. Truck has about 47k on it. Any ideas???
First items I would check is the APPS (throttle position sensor) and the pressure valve in the CP3 injection pump. APPS could be sending an erroneous signal or the pressure valve is sticking.
MikeyB
MikeyB
ClayBob
08-07-2009 09:41 AM
jmccart
06-12-2007 02:12 PM
skeeter
01-18-2006 03:17 PM
dieselnewbie
04-13-2004 12:00 AM
fishin fever
02-22-2004 08:32 PM
