Royal Purple 15W40 Synthetic
Anyone use this yet. I've heard good things...so on my last oil change, I filled with RP. The first thing I noticed is that the engine seemed quieter, next was that at cruise (70) my EGT's on Level 3 are normally around 750. After RP, I'm only at about 600? Would the synthetic cause the engine to run that much cooler? I normally run Rotella 15W40.
Yes, less friction means less heat so it should alittle cooler. You should have also noticed that your RPMS at 70 were less than before the synthetic because of less friction. You may have also noticed that your normal oil pressure is also less thatn with dino oil. Don;t worry as long as thepressure stays in thenormal range once it's warmed up.
All of these things normall equate to better fuel mileage, however do the engine running quieter you will have the tendacy to go faster so you offset the fuel mileage gain by the better feel of power
By the way, I'm using Royal Purple in my Acura 3.2TL-S and my wife's Durango 5.9L right now and am pleased with its performance.
Rusty
D384D
06-05-2009 09:54 AM
Roperteacher
07-15-2007 07:11 PM
Mark Thomas
07-10-2003 09:07 PM
