Rough idle at start and white smoke.
Old 01-29-2008 | 10:54 AM
tx270's Avatar
Just the other day out of nowhere when I started my 05' (60,00 miles)it idled rough for about 2-3 seconds and blew a fair amount of white smoke. Temp was around 45 outside. Has never done this before even in much colder weather. Has done this several times now. Runs perfect after the first 2-3 seconds. Did it the other day after sitting just three hours in mid 50's temps.
Just drained water/fuel seperator the other day and Fleetguard filter has about 6000 miles on it.
Any ideas? My own idea leads towards bad injector or heating grid going out.
Thanks,
Bill
05', 4x4, G56, QCLB
Old 01-29-2008 | 01:38 PM
Texasimport's Avatar
A sign of a sticky/leaky injector. . . .start with a good bottle of injector cleaner in your fuel. . . .then see what you get. . . .
Others have said you might need to run it pretty hard being a med duty engine to keep those injectors nice and clean.
Old 01-29-2008 | 07:57 PM
t-boe's Avatar
There is a tsb flash for that. I had the same problem and it took two injectors to fix it. So it could be either or.
Old 01-30-2008 | 07:52 AM
homewrecker's Avatar
I had the same problem.Upgraded to F1 injectors and still had it.Problem went away with newest Smarty download.I guess because smarty has newest DC flash files.
ChrisG
08-19-2008 03:28 PM
J Banning
27
09-13-2007 12:22 AM
rws
07-02-2007 12:41 PM
wilderness
24
02-19-2007 12:41 AM
walt_mink
35
09-01-2005 04:43 PM
