rough idle sometimes
My truck just started idling rough yesterday. It has always idled really smooth. I stopped at a traffic light and it felt like a gas burner with a fowled plug. I have 58,000 miles, any suggestions? Possibly injector?
Not sure if you have changed it before, but here is a great step by step from one of our members:
https://www.dieseltruckresource.com/...n&onlynewfaq=1
i don't want to sound like a broken record but throw a full bottle of either howes meaner cleaner or seafoam info the fuel tank and either pull something with your truck or run it hard.
First thing I'd do is pour a bottle or two (or three) of Sea Foam in the tank. If it's a fouled or dirty injector then that will most likely cure it.
My did the same thing earlier this week and Sea Foam seems to have smoothed it out. If nothing else works your engine is still under warranty. Have the dealer look at it.
Yes, put some pull system/injector cleaner in there. I had the same problem and I put some Power Service cleaner in there and the problem went away... Well it came back about 10K miles later so I put some Lucas in then the next tank I used Seafoam.... All is good with my idle again.
sawboywv1
25
06-30-2009 05:09 PM
Ridiculous
14
05-21-2007 09:11 PM
