Rough Idle low end chatter knock
Seems my truck just in the past days has developed a little chatter or knock after shifting, goes away when the rpms go up seems to idle a bit rougher. 61000 miles oil pressure and temp are fine. gonna do a fuel filter and see if that clears things up.. thoughts?
Good Luck
You may even want to ring Peter @ South Bend. Describe your issue to him.
He's great wealth of information and a good listener
I didn't have a DMF but had a clutch which would slip even with the slightest aggression, a pressure plate and bearing that chattered like crazy. Heck, even my FR & RR tranny seals were leaking
I feared the same but drove it with care (sometimes anyway) for about 8 months/16K kms and it held till i could afford the overhaul and my SBC
Good Luck & Keep us Posted
When idling does the chatter go away when you press in the clutch? I have a 2006 Dodge 6 speed manual 71k miles. A few months ago i began to here a chatter at idle and while pulling heavy loads. About three weeks ago i put a solid flywheel and clutch in it and after about a week the chatter got about three times louder. I pulled the tranny back out and found that the input shaft had some up and down movement in it. I pulled it apart and found that both bearings on the input shaft were shot. The only place i found that lists bearings for it is dodge
Grey Goose
09-07-2010 09:32 PM
HappyGA
15
10-16-2006 08:21 AM
Hoss
30
10-03-2006 02:57 PM
mikeempire
09-19-2006 05:13 AM
