Rough High Idle during Cold Weather
Old 01-14-2008 | 06:48 PM
alramr's Avatar
I am a new member to this forum; however, I have been reading this forum for a while and decided to join. Some real good discussions, unfortunate problems, and good solutions.
I have stock 2005 (e.g. no modifications) and has about 50k miles. After starting, the truck goes to high idle after about a minute or two; however, during high idle it sounds as if the truck has a hot cam. I change the air filter every 12,000 miles and fuel filter every 6,000 miles - strictly road miles. The air filter appears clean; however, the filter minder shows it is becoming a little restricted. I purchase fuel (ULSD) at two service stations on a regular basis and I'm afraid to ask the person behind the counter if the fuel is winter blend - since I may get a dumb founded look.
After about 10 minutes - I depress the accelerator pedal or brake and it resumes to a normal idle without it sounding as if it misses. There is no white smoke - and it rough idles when temps are near or below freezing. This happens with and without the catalytic convertor.
I do not think it could it be the CP3 pump or the pump in the fuel tank. Sensor? Injectors? Or do I need to change the fuel filter more often.
The truck is still under warranty. Thanks for your help.
Old 01-14-2008 | 07:07 PM
scootertrash35's Avatar
i change fuel filter every 15k,and change air filter(stp)at 10k
fill in your sig so we know what your workin with and good luck
Old 01-14-2008 | 07:38 PM
Black SunShine 04's Avatar
It's the grid heater cycling that makes it surge
Old 01-14-2008 | 08:59 PM
alramr's Avatar
Black Sunshine
Does your 04 surge similar to mine? Do you think my grid heater needs to be replaced?
Thanks
Old 01-15-2008 | 04:32 PM
No it just draws a lot of voltage when it cycles and when you high idle is up it pull on it. It'll be ok man
Old 01-16-2008 | 06:57 AM
yfz431's Avatar
'05 with 56K here and I have been having the same issues recently with a mis at high idle and it occurs without the grid heaters cycling, and most recently when sitting at a stop light with my foot on the brake pedal and normal idle. I have the Quadzilla Box and it does it in all settings, on or off. No smoke. Runs strong. No CEL. I first noticed the problem this winter season. I have replaced filters, added Powerservice diesel cleaner w/ MMO, tried different fuel stations. The engine is quiet when driving. It misses/shakes like something is out of balance? I'm wondering if it could be injector related?
Old 01-16-2008 | 07:56 AM
vzdude's Avatar
DTR's 'Go to Guy'
It is called 3 cyl idle. Only happens if it is cold enough. Some will say that 3rd gens don't do it, but I have experienced it in mine. The biggest thing for me is....no codes. If it were a problem, there'd be a code. These ecm's are very particular about engine misses and such and can pick up even a slightest miss. ( unless of course the ecm is telling it to do it like when in 3 cyl idle mode!)
Old 01-16-2008 | 08:00 AM
BIGDAN65's Avatar
do you plug in block heater?
Old 01-16-2008 | 09:02 AM
yfz431's Avatar
I do not plug in a block heater. Mine is not isolated to only on first start up, although it does do it then too. It will do it after driving it for 2 hours, stop, let it idle up to high idle, then start to mis/shake. I'm not going to worry much about it, yet. No codes, fluids ok, no strange noise. Although the older the truck gets, the more miles I put on it, I tend to notice more vibrations, shaking, misses, etc and I try not to let it drive me nuts This is the longest I have ever kept a vehicle, they are usually gone with under 18k, but that was getting way too expensive
After I posted, I got to thinking that I may have highjacked the thread and that was not my intention Sorry to alramr. But hopefully what I posted can trigger some others thoughts and relate to the original post.
Old 01-16-2008 | 06:19 PM
alramr's Avatar
No offense - whatever it takes to get a solution. I heard of the 3rd cylinder issue; however, thought it only related to 03 or 04 models. My problem only occurs during initial start up and once on the road and sitting at a stoplight it does not occur. I will get it looked at and get to the bottom of it. My wife's brother in-law thinks it is a fuel filter issue which I know it is not. I tend to lean toward vmdude statement of ecm or injector issue or an earlier response of heater grid cycling. At least I have a starting point.
Old 01-16-2008 | 09:26 PM
Hounddog's Avatar
I still think its a rough running issue and not a 3 cylinder warm up suppose to do this issue.But hey what do I know.
Old 01-16-2008 | 09:54 PM
Texan1983's Avatar
what is this 3 cyl warm up mode?
Old 01-17-2008 | 05:52 AM
yfz431's Avatar
Alramr, what micron fuel filter are you using? Could the rough running issue be related to the fuel filter? A while back, I believe the fleetguard filters changed a bit, and went from 5 micron to 2 microns. Anyone see any need to change the 2 microns more often?
Old 01-17-2008 | 12:49 PM
DBLR's Avatar
yfz431,
I do know that Fleetguard went from a 10 micron down to a 7 micron. I've never heard of Fleetguard making a 5 micron let alone 2 micron fuel filter for our trucks. The only one I know about who makes a 5 micron for our trucks is Baldwin, part number PF 7977.
Old 01-17-2008 | 01:40 PM
Neven's Avatar
My 06 does the same and I'm sure it's the heater doing its thing.
Quick Reply: Rough High Idle during Cold Weather
