Replacing cracked Transfer Case Half.
I have a crack in the front half of my transfer case which I think may have been caused by a bad u-joint. I'm going to either replace or rebuild the driveshaft but I'm wondering how hard it would be to replace the front half of the t-case and just swap the guts into the new one.
Is this a huge job? Very involved?
Special tools needed?
I've swapped lots of whole trannies and t-cases but never opened one up.
Thanks for your help.
Can't be that bad, if you can remove them, find a manual that has directions and specs and I would think you will be fine, worst case is you have to bring them to someone to finish.
Ranger391
07-05-2010 06:54 PM
