Removing the Silencer Ring
Thats MR Hoss to you buddy!
As I understand it, removing the silencer ring will only make the whistle of the turbo louder....not the "diesel" sound, correct??<br><br>Given that, how would one go about removing the silencer ring? Where is it located? How hard is it to remove for someone who is above average on mechanical skills (above average meaning more mechanically inclined than the average nut...but probably just average with the folks around this forum)?
Re:Removing the Silencer Ring
it is on the compressor side of the turbo. It is held on by a large snap ring. Two flat head screwdrivers and 5 min and its out. easy as putting a seat cover on.<br>DM01
Hoss just my 2 cents you could void warranty on turbo by doing that. Sounds like crock of u know what but they could do it if they want to if they found out you took it out.
"Sir, it appears that your silencer ring has been removed."<br><br>"What's a silencer ring??" ??? ??? ???<br><br>
<br><br>Seriously....how many people do this and has anyone had trouble with a warranty because of it?? Does it HURT anything to take it off...or just make the turbo whistle a little louder?? If it takes 5 minutes to take off....could I put it back on in 5 minutes if I had to go in for service??<br><br>Anyone got any pictures of what I'd be looking for if I removed it??
![Wink](https://www.dieseltruckresource.com/forums/images/smilies/wink.gif)
[quote author=Hoss link=board=20;threadid=15317;start=0#143837 date=1054302902]<br>"Sir, it appears that your silencer ring has been removed."<br><br>"What's a silencer ring??" ??? ??? ???<br><br>
<br><br>[/quote]<br><br>Exactly!
<br><br>The snap ring and the ring itself are reinsertable very easily. As a cautionary not though, the snap ring can be warped and twisted during removal making its replacement quite difficult. Use care getting it out.
Hoss go to the search button type in SILENCER RING
there are some pic. somebody else posted. pic of ring in and the ring out. Big clear photo.
HOSS: The silencer ring was only put into the dodge trucks. The only perpose it serves is to "quiet" the turbo down, i.e. make it more of a nice driving rig for the avrage person going down the hwy. That's the only perpose. Removing it should do nothing to the warrenty at all. It is very easy to do. I found that a #2 flat head screw driver and a "pick" works better than 2 screw driver's. Use the screw driver to pry the end of the ring down then use the pick to get in behind it and pull er out! You will enjoy the sound! 8)<br><br>
Hoss, I did mine one day while waiting for my turn at the fuel pump. That evening my wife drove the truck. When she got back, she said something like "I Like it, what did you do?"<br><br>Now if I could just get her to kick loose a little $$ for essentials, like fueling box, trans, stacks, flat bed, chrome, new paint..... Oh well, try it. You will only really hear it if you change your filter, but it is real easy to swith back and forth.<br><br>Glad you like your new truck.<br><br>Ed
Hoss,<br><br>If you haven't removed your silencer ring yet go to the High Performance forum and check the post on silencer rings. I posted some pictures that should help you out. It's very simple to do.
I took mine out tonight and noticed that there is an opening behind where the ring was. Is the turbo able to get a little more air now or is it not big enough to do any good? It sure sounds good though! 8) ;D<br>Kris
Haven't done it yet. I did raise the hood and try to figure out where it was exactly...but no such luck. [undecided]
