Removing intake manifold plate??
Trying to replace intake seals to fix a boost leak. The one that is leaking is the manifold plate (long rectangular 3in x 15in). Does anyone know if you can get the manifold plate out if you remove intake horn/grid heater and the fuel line clamps?? Or am i going to have to pull the injectors and fuel lines to get that thing out?? Looks like it might slide out towards the front with the fuel line clamps off but i can't tell. Also, has anyone been able to re-use the seals on the grid heater or should i replace them??
Thanks!!
Thanks!!
BA05'CTD
01-07-2007 03:08 PM
Bobcat698
09-24-2005 10:51 AM
