Removing Front Driveshaft
Old 11-16-2008 | 12:27 PM
D45's Avatar
D45
What do I look for, to indicate the driveshaft ujoints may need replacing?
Old 11-16-2008 | 06:28 PM
D45's Avatar
D45
The front driveshaft came out without any issues.
I think the front torx bolts were alot easier to remove than the rear bolts, at the tcase.
Anyways, thanks for the info. All the joints were tight and moved freely, and did not show any signs or symptoms of needing replacement.
Old 11-17-2008 | 01:47 PM
duallydave's Avatar
mine was worn on the needle bearing part where the 2 joints pivot,i dont know why they need the double u joint idea,its not a steep angle at all,mine was vibrating to so i take it off for summer and install in the winter,i guess i shoud just fix it haha
Old 11-21-2008 | 08:42 AM
paydirt's Avatar
I was thinking about doing the same thing. Removing the front driveshaft to eliminate it as a vibration source. My question is.....before removing it do you need to mark it somehow on both ends to ensure it gets re-installed in the same position?
Thanks in advance..
Old 11-21-2008 | 09:00 AM
Fisherguy's Avatar
It's a good idea to mark it at the diff and the trfr case, at least that's what I did.
I finaly got some grease into that PIA joint while I had it on the bench too...
Old 11-21-2008 | 09:27 AM
D45's Avatar
D45
At the axle end of the shaft there are grooves that will also line it back up
Bowser50
33
07-21-2013 06:33 PM
wesl
10-23-2012 08:48 PM
Commatoze
07-15-2004 06:44 PM
BigBlue
09-18-2003 11:29 AM
Quick Reply: Removing Front Driveshaft
