Removing Front Driveshaft
How hard/easy is it to pull the front driveshaft?
I have a grinding noise that I would like to rule out as coming from the front driveshaft
Any special tools or items needed? Are the bolts normal hex head or are they torx?
Also, will it be ok to drive the truck without the front shaft installed and not have ANY fluid leak out from the tcase?
Thanks for any and all info!
As 05 CTD2500 said, make sure you have a good solid long t40 torx bit that fits in there straight. You will need to apply a lot of pressure to get them loose. They use thread locker on the threads.
From what I have read, the front bolts have red LocTite on them......and the rear bolts are rather easy to remove.
I am going to hopefully get the driveshaft removed tomorrow and see if it solves the grinding noise....
You CAN use an ordinary torque socket as long as you turn the drive shaft to get a good angle on each bolt. I used a 3/8" socket on mine, just jack up the front drivers wheel so the driveshaft will turn so you get a good angle and you'll be okay.
For the other end its easier if you take the skid plate off first.
Towed 3400 miles at a GCVW of over 19,000 lbs with the front drive shaft off and had no problems. It just made my truck a tall 4X2 for that trip. I was trying to isolate a vibration that turned out to be the same u-joint that had been replaced 3200 miles prior to the trip.
Thanks for the info.......I am going to try to remove the shaft this afternoon.
Would it be a good idea to replace the stock u-joints with aftermarket parts, since the truck has 67,000 miles on it and the driveshaft will be off anyways?
