Removal of stock fuel filter housing
Old 05-20-2009 | 08:52 AM
bierk76's Avatar
I am planning to remove the stock filter housing as I've completely bypassed it with my current setup. However, I want to have an idea of what I'm going to be getting into and what the correct procedures are. Does anyone have any input/direction on the proper way to do it with minimal hassle?
Thanks!
Bierk
Old 05-20-2009 | 11:09 AM
cdennyb's Avatar
From: In Oroville, Ca., same house for past 46 yrs!
why would you remove the stock filter with water drain and fuel heater option? I dont know which filter housing you arre referring to but mine is on a 03 ram 3500
https://www.dieseltruckresource.com/...=181485&page=6
post number #82
Old 05-20-2009 | 11:35 AM
bierk76's Avatar
post number #82
I want to remove the stock filter housing on the side of the block because it is no longer in use. I live in FL so I don't care about the fuel heater, nor any other part of it. I have far superior filtration with the cat IR-750 and I have a separate 20 mic fuel/water separator before that cat filter. I consider the stock filter location to be less easily serviced than what I have now, as well as the filtration is nowhere near as good. I much prefer this setup and the stock housing is just in the way at this time but I want to make sure I take it off in the proper fashion.
Old 05-21-2009 | 08:56 AM
hotrod929's Avatar
look at GDP they have a filter delete plate. works great. what i used.
HotROd
Old 05-21-2009 | 09:48 AM
AH64ID's Avatar
Does your 20mic have a WIF sensor?
I have extra filters like you, but keep my stock canister.. its one more place for water/debris to be caught.. and it has the WIF sensor. Honestly you only have to get to it every 15-20K miles.
Old 05-21-2009 | 03:46 PM
DaveB.inVa's Avatar
I left mine in to make a staged system. Progressively filter down and everything will last longer. Thats how big stuff does it. May not be an issue though.... just my opinion.
Tiara3100
12-21-2007 01:42 PM
vwjunkie53
11-03-2007 11:01 AM
JP-4.5
10-09-2007 12:44 PM
Bham Ram
03-29-2007 05:00 PM
HOHN
12-07-2003 02:07 PM
Quick Reply: Removal of stock fuel filter housing
