Redline ShockProof
Redline ShockProof
thinking about getting the "Heavy" shockproof for the diffs in a couple trucks, a 02 with dana 60 and 80s and the 04 below,
Ive read how great the oil is in high temp conditions, but how is it at -40, when nothing wants to move, same with the Redline MTL for the nv5600s, will they lubricate properly,
I cant find any info about pour points or viscosity and -40, any help would be great
Re: Redline ShockProof
I found the info, its a little to sluggish for -40
Typical Properties
Heavy
ShockProof
Brookfield Viscosity,
Poise 1400 @ -40°C
Pour Point, °C -42
Pour Point, °F -45
Flash Point, °C 224
Flash Point, °F 435
Density, g/cc, 15°C 0.94
Calcium, %wt 4
Phosphorous, %wt 0.2
Molybdenum, %wt 0.6
Synthetic ShockProofâ„¢
Gear Lubricants
and some more www.redlineoil.com.au/Uploads/Downloads/finalbook%20reviseI(1).pdf
it says in here that heavy shockproof is not recomended for -25C and below
Typical Properties
Heavy
ShockProof
Poise 1400 @ -40°C
Pour Point, °C -42
Pour Point, °F -45
Flash Point, °C 224
Flash Point, °F 435
Calcium, %wt 4
Molybdenum, %wt 0.6
Gear Lubricants
Shockproof Heavy is a GREAT geear lube. The stuff is like paint! I had to use a solvent-based cleaner (brake cleaner) to clean my diff cover when I did my last diff oil change.
It coats and sticks really well to the gears. It leaves me with the impression that it all but eliminates dry starts of the gears.
The Heavy stuff is VERy thick. It's tough to pour out of the bottle. But I think it protects very well in heavily loaded differentials. If you tow heavy, I believe it would probably be the best oil available for you at any price.
It DOES sacrifice some efficiency for the protection, and MPG will be a hair lower with the SP heavy.
If you are not sure about the shockproof, try the regular Redline gear oil in 75-90 or 75-140. Both are great products.
Redline's products are generally pretty decent, but I believe their gear oils to be the best in the world, even if their other stuff is just simply "good."
JMO, as always.
JMO, as always.
CumminsRedneck
10-13-2014 04:49 AM
Battering Ram
06-06-2003 08:58 AM
