Redline in 6 speed?
Old 09-08-2005 | 05:12 PM
glowball's Avatar
Redline in 6 speed?
Just making sure I order the right stuff. I need redline mtl for my 2004 6-speed right? And is it 4 qrts?
Also what is best to put in the transfer and the front and rear ends?
Thanks
Kris
Old 09-08-2005 | 05:17 PM
MikeyB's Avatar
Yes, Redline MTL for the NV5600. The tranny will hold 4.5 quarts, all little more if you jack up the rear of the truck.
Transfer case is ATF+4
Front axle use synthetic 75w-90 and the rear synthetic 75w-90 or 75w-140.
MikeyB
Old 09-08-2005 | 07:38 PM
Jeff in TD's Avatar
I just did the MTL thing... I'd be sure to pull the PTO cover to clean the magnet.
I was shocked how much was on mine after only 27,000.
Old 09-08-2005 | 08:04 PM
DSLRammin's Avatar
Mine would only take 4 quarts. i called the dealership and they said 4 quarts, so I bought 5 just in case. The truck was pefectly level, and even at 4 quarts, it started pouring out the fill hole. Should I jack up the rear and add more?
Old 09-08-2005 | 08:43 PM
Jeff in TD's Avatar
Did you pull the PTO cover, or just the bottom bolt?
I pulled my cover and there was still quite a bit of old oil sitting in the bottom of the case that I pumped out, then put in about 4.5 q...
Old 09-08-2005 | 10:14 PM
wap's Avatar
wap
How bout the G56, in the manual it says to use ATF, does redline have a good ATF or is there one better? And does anybody know how much it will hold?
Old 09-08-2005 | 10:21 PM
vctowpig's Avatar
I would like to know the same also!
Old 09-09-2005 | 01:40 AM
DSLRammin's Avatar
I didn't pull the cover off. Do most of you pull the cover off?
Old 09-09-2005 | 07:17 AM
MikeyB's Avatar
My first tranny fluid change I pulled the PTO cover off and cleaned the magnet. The magnet had a fine layer of metal attached.
The G56 requires ATF+4. I heard the tranny holds 7 quarts which is above the fill hole.
MikeyB
Old 09-09-2005 | 10:25 AM
Maccandy's Avatar
Which side is the magnet on?
Old 09-09-2005 | 07:58 PM
Jeff in TD's Avatar
The magnet is just sitting in the bottom. Mine had a bunch of metal on it (photo in my gallery).
I pulled the right cover, and it was easy to reach in get the magnet.
Old 09-10-2005 | 09:55 AM
rossn2's Avatar
Yes, Redline has C+ Auto Tranny fluid. And, they have 75w-90 Gear oil for front and rear end too. If you order the 75w-90 get the stuff with the ls additive in it, instead of the 95w-90NS oil. It will emlinate any rear end chatter. Yes, I know these trucks don't have clutch packs in them.
Cheapest place I ever found was www.myoilshop.com out of PA. THey ship it directly to your house! Almost everything is $7 a quart.
Old 12-05-2005 | 02:30 PM
twoshot's Avatar
I thought Redline MTL wasnt a G-4 oil ??????
Old 12-05-2005 | 03:14 PM
rossn2's Avatar
Someone gave you bad information that MTL isn't GL-4 . Matter of fact, I have some left over and will be replacing wife's Hyundai Santa Fe 5 spd transaxle fluid with the MTL in about 30.days.
http://www.myoilshop.com/AutoPrds.html
Old 12-05-2005 | 05:24 PM
bulabula's Avatar
I've run both Amsoil and then Redline MTL in the tranny; my tranny shifted nicer after the Amsoil. Next time, Amsoil will go in again.
Quick Reply: Redline in 6 speed?
