Rear end fluid ?
Old 03-18-2006 | 05:51 PM
Phil n Az's Avatar
Rear end fluid ?
I have a 04.5 2500 with limited slip diff. How much fluid to refill after r&r the diff cover ? Thanks , Phil
Old 03-18-2006 | 05:59 PM
timcasbolt's Avatar
less than 4 quarts
Old 03-18-2006 | 06:07 PM
Pop-Pop's Avatar
For the 11 1/2" gear, the rear end takes 3.62 pints of 75W-90 full synthetic gear oil. This will be about 1/4" below the fill plug (you can stick your pinky in to guesstimate the level).
Old 03-18-2006 | 07:35 PM
koogala's Avatar
Did mine 2day. 3.73 rear took little less than 3 1/2 qts. don't know size of gear.
You can also bend a bread sack tie at a 90, hook'er in & measure that way.
Tried a paperclip 1st; couldn't see oil on it as good as a breadsack tie.
LockedandLoaded
01-17-2008 02:51 PM
doorguy
06-08-2007 06:19 AM
Mr. Jimmy
17
05-12-2005 11:32 AM
supr
15
08-04-2004 03:33 PM
gdh11
11-14-2003 09:51 AM
Quick Reply: Rear end fluid ?
