Rear Differential Oil TSB
Old 11-09-2004 | 09:08 PM
  #31
ckennedy's Avatar
i started to post right above and retracked it... now I think I will post anyway.
people *** MAY NOT *** be reading the complete thread... so here I go on the 75 - 90 vrs 140 wt. oil.... If you are looking at the beginning of the post and ASSUMING that the 70 - 140 wt. oil is the correct wt.... I do not think it is.... I posted above on the beginning of page#2 that the GENO's TSB was a old release dated Jan. 04... and DODGE TECH AUTHORITY web site had a "newer" release of the TSB dated May 04... the DODGE tsb stated to use what the manual states... 75 - 90 wt... I am just noting this again because I still see people thinking/talking about using the 140 wt...
it alll... I may call myself in AM and find out...
Old 11-09-2004 | 09:20 PM
  #32
BART62's Avatar
WOW I was confused. I guess I'll use what the manual says to use. I think I will also call the dealer and see what they say.
BART
Old 11-10-2004 | 03:36 PM
  #33
Big Jimbo's Avatar
Ckennedy
The TSB I initially referenced at the start of this string that states the new recommendation for 11.5 is 75w/140 oil was dated May 11, 2004, and says it supersedes the Jan 13, 2004 TSB!
Date: May 11, 2004
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 03-001-04, DATED JANUARY 13, 2004.
(DR) RAM TRUCK 2500 - 3500
AXLE FLUID LEVEL
(measured from the bottom of the fill hole) FLUID CAPACITY
10.5 Rear Axle 25 mm (1 in.) ± 6 mm (1/4 in.) 2.5L (85 oz.) - SAE 75W-140 Synthetic
11.5 Rear Axle 6 mm (1/4 in.) ± 6 mm (1/4 in.) 3.6 L (122 oz.) - SAE 75W-140 Synthetic
9 1/4 Front Axle 6 mm (1/4 in.) ± 6 mm (1/4 in.) 2.2 L (76 oz.) - SAE 75W-90 Non Synthetic
Do you have a link or a copy of the TSB you could share that supersedes the May 11, 2004 TSB?
Old 11-10-2004 | 04:17 PM
  #34
ckennedy's Avatar
Jim -
Thanks for the note... first let me say seems like I am half right...
You are indeed correct about the tsb at top of thread... don't know how I got it wrong but I did.. guess I have to many tsb's floating around... BUT I will upload the DODGE TECH AUTHORITY tsb ** dated the same day, MAY 11 *** BUT does not have the 140 wt. oil listed.... hmmmmmm. now this can get confusing....
guess I need to be more careful about trying to help...
ps: will upload and post link asap...
Old 11-10-2004 | 04:35 PM
  #35
ckennedy's Avatar
here it is... my get out of jail free card.
http://home.satx.rr.com/sandmanxx/axle-fluid.pdf
ps: don't know what to say but guess it is time to call the dealer...
Old 11-10-2004 | 06:04 PM
  #36
MikeyB's Avatar
We have the same rear end (11.5 AAM) as the GM HD series. And GM recommends 75-140 synthetic for heavy towing.
MikeyB
Old 11-10-2004 | 06:05 PM
  #37
Big Jimbo's Avatar
Wow! That makes it clear! There is no correct answer! You can choose which ever TSB you want to support your use of 75w/90 or 75w/140 oil for your 11.5 axle
Since I just put in the 75w/140 (and paid twice as much the 75/90 wt) and since it is so hot in AZ I will run with it.
At least both TSBs agree on filling to the hole
I would ask the dealer but I don't think they ever read the TSBs. Maybe this is why. It may be best to just follow the owner's manual unless you get a letter from DC telling you to do otherwise.
Old 11-10-2004 | 06:11 PM
  #38
Nevada's Avatar
Originally posted by Jim O
I wonder if GM has changed their spec for the Dmax trucks as they have the same Diffs?
I just changed my diffs again (Mobil 1 75-90 synthetic) I have a Grande Cherokee that calls for 75-140 and I know DC are very proud of that oil as is reflected in their price. I just bought a case of the Mobile1 75-90 and I will use it up in the Front diff ( because of the cold weather that we can get up here,I will continue to use synthetic in the Front diff.) Who else makes a 75-140 synthetic besides DC for my next change?
Jim O
Both weights are available as Mobil One products. I have a quart bottle of each in my garage because my wifes Ford Escape requires the heavier weight in the PTO.
Old 11-10-2004 | 11:04 PM
  #39
Jim O's Avatar
Thanks Nevada
I only have about 1000miles since I changed oil in both diffs
(mobile1 75-90) and after the new year I plan to pull my fifth wheel from up here in Canada to Daytona for the Daytona 500 and back to Vegas for the Nascar race there in March. I may only have a few thousand miles on it but I think I will look for the Mobil 1 75-140 and change the rear diff before I leave.
Jim O
Old 11-11-2004 | 11:38 AM
  #40
Jonesey's Avatar
Unless I receive a TSB from DC in my mailbox I will follow the procedures as stipulated in my owners manual. I thought it was ridiculous that you have to change the differential fluid at 15K mile intervals, but it just keeps getting more ridiculous.
Old 11-11-2004 | 01:37 PM
  #41
Peterbilt's Avatar
I think I will get both and mix them and have 75W115 and fill it to 1/2 below the hole .
Pete
Old 11-11-2004 | 02:30 PM
  #42
cquestad's Avatar
That sounds like the best idea yet...split the difference!
Old 11-11-2004 | 04:17 PM
  #43
nonford's Avatar
Well, hell's bell's! I just replaced mine with Royal Purple 75/90! Saw this thread and ! Well, it's in the owners manual to use 75/90 and I haven't had problems. I guess it if it were a real issue, we may have gotten something in the mail to get it right. I don't know. But that's my story and I'm sticking to it.
Old 11-12-2004 | 08:20 AM
  #44
sawboywv1's Avatar
I too will stay with 75-90 until I get something in the mail informing me otherwise. And as far as filling to the bottom of the hole goes... I did that 3 times and 3 times the rear pinion seal failed, leaking and throwing oil everywhere. It would come back from the dealer low (or I thought so) and I would "TOP OFF". Only to have it fail later. Last time I measured down 1/2". 15k and good to go! Do what you want to. I have learned there are a whole lot of arm chair wrenches on the net.
Old 11-12-2004 | 12:22 PM
  #45
1sttruck's Avatar
I changed mine at 15k miles and filled with M1 75w-90, to the hole. The rear still looks ok but the front leaked a bit on one side. I'll probably try 1/4in below the hole the next time.
tndiesel
11-06-2011 08:08 PM
twhman
27
07-16-2006 12:36 PM
wilnis
05-14-2005 12:06 PM
Adieselbrother
03-21-2005 04:27 PM
t-15 firefighter
14
10-22-2004 11:10 AM
