Rear Differential Oil TSB
This is an old topic but I just saw a TSB on Geno's site that got me wondering what to do. The TSB is dated May 11, 2004 and the build date of my truck is May 2004. The TSB says the 11.5 rear diff as well as the 9.25 front diff should both be filled up to the fill hole with oil! My rear diff cover has a fill line on it that is about an inch below the hole. Do I now fill it up to the hole? I would think so if this is a new TSB! Also they say the rear should have 75W-140 synthetic oil and the front diff should have 75W-90 non-synthetic oil! What's up with this?
I was going to change my oil this weekend but now don't know what I should buy.
Re: Rear Differential Oil TSB
I will try to post the link to the TSB:
http://dodgeram.info/tsb/2004/03-001-04A.htm
Thanks for the link. I see they still say +/- 1/4 inch from fill hole. I do not think 1/4 will make a difference in the way the diff's perform. I would rather have a little more lube in them than a little less. I do like the fact that the now recommend the 75/140 lube.
just a note in case you did not see it... you need to read the fine print on the TSB... states NOT all drain holes are located correctly...
you need to MEASURE the distance/etc.... do just fill to 1/4 in. to hole... that may not be right!!!
That TSB just makes it clear as mud. Do I fill the rear end to the line which is ~3/4" below the hole or 1/4" +/- 1/4 below the hole? Do I use 75W-90 (which is what I used) or change to 75W-140? Why can't they get something as simple as this straight?
Greg
Here's the skinny from AAM...
Thank you for contacting AAM. We hope the following answers your questions.
10.5" Axle lube fill is 2.5+/- 0.2 litres
11.5" Axle lube fill is 3.62 +/- 0.2 litres
Newer AAM axles have a fill level mark on the coverpan. Neither volumetric levels come up to the bottom of the fill hole. Overfilling will probably reduce your axle efficiency (fuel economy), but should not damage the system.
Best Regards,
AmerIcan Axle & Manufacturing
Best Regards,
Best Regards,
Best Regards,
Best Regards,
Best Regards,
I just changed my oil this morning and I measured out exactly 122 oz just like it says in the TSB. The level came out to EXACTLY at the bottom of the fill hole! This is about 1" higher than the "fill line" on my cover! The other thing that surprised me was the price of the 75W-140 synthetic. It is twice the price of the same brand 75W-90 synthetic. I paid $15/qt at Checker for 75w-140 Mobile 1 vs $7/qt for 75W-90 I checked other stores and found the same thing. Is the 75W-140 twice as good?
It seems there is lots of confusion at DC
Originally posted by sawboywv1
filling to the hole will make em LEAK!
