Rattle/odd noise at 1100 to 1400 rpm...
This just appeared, it's extremely prevalent from 1100 - 1400 rpm. It sounds like a ratchet spinning REALLY fast....or the way a faucet sounds when you just barley turn it on. Much louder when coasting before the tranny disengages. No rough idle but the little lady says, "it sounds a bit throatier".
Any thoughts?
Any thoughts?
Any thoughts?
Any thoughts?
If you do have a built trans, open the inspection plate and see if you have a bolt flying around. Try to wiggle the plate and see if it has play. If so, you have to pull it and tighten all the bolts!.
I may be completely off but, it's worth a look into..
I have not had any tranny work done.
I'm pretty sure that's not the problem ( although, I did explore the idea).
I've been listening much more, and it seems the sound is more than just 1100 to 1400. It's just muffled by the engine noise at higher RPM.
EverydayDiesel
07-23-2008 10:46 PM
