Raptor fuel pump noise
I have a raptor fuel pump on a 03 and a 04.5. I put both of them on about 2 years ago. The pump on the 03 has become much louder than it used to be. I have also confirmed this by comparing it to the one in the 04.5. It makes a grrrrrr sound. Any ideas?
Do you have a fuel pressure gauge installed?
I am sure someone will chime in to inform you that the Raptor pumps are junk. They certainly are not as reliable as they once were.
Are you showing any codes using the key on/off method? You could also try to re torque the connector tubes to the proper torque value.
The truck is not showing any codes. What tool is used to torque the fuel lines? Looks like a open end wrench is required and a tight fit on some of them.
03veggieram
03-16-2008 11:42 PM
84mphcdt
16
12-19-2007 11:31 AM
