Random High Idle
Random High Idle
I have a problem with my 03 randomly going to high idle. It almost acts like it is still cold and is idled up due to temperature. It usually happens after running at speed on the highway. When I come to a stop the engine will sit at about 1000-1100 rpm, but if I push the brake hard enough it will slow back down to normal 750 rpm. Once at 750 rpm it will stay there until I drive off, ie at a stoplight.
Truck is a 6 speed, and this happens with the quad box on any of the 4 settings, and also with everything unplugged and back to stock. I have found no evidence of fuel in the oil, and egts haven't changed appreciably from stock (little lower since the exhaust). Truck currently has 97K and other than this no problems.
Any ideas? (Please don't say injectors...)
My 03 has done it since new. I posted that I thought it was from other parameters besides IAT but no one agreed. I'll get it when (I believe since I haven't measured anything) the engine is still hot after a run, when I have extra load on the alternator, or with my AC running at idle.
I'm not worried about it since it seems to be at good times when it does it.
Same problem here
I have the same problem on our truck. It idles up to 1000rpm especially when I just start to accelerate then push in the clutch. If I push the brake in hard it idles down again. Would love to find a solution to it. No codes here either.
My '03 has done it since it was new...but only does it during cold weather. I can drive it for hours at a time and, only if the outside temp is cold, it will randomly go into high idle. I hauled almost 25k lbs to New Mexico a few years back and after pulling for almost 10hrs straight I pulled over because nature was knocking on the door and almost instantly it went into high idle and the outside temp was around 40*. I know about the temp and high idle coinciding with each other, but pulling for that distance the engine should have no reason to idle up. I just quit worrying about it because like others have stated, if you tap the brake pedal it idles back down.
robert78.5
17
07-22-2015 03:06 PM
dodge_sledder
11-04-2007 10:21 PM
jmccart
06-12-2007 02:12 PM
