Radio Interference
Radio Interference
I turned to an AM radio station this morning and noticed radio interference that sounded just like ignition noise from a gas engine. It was coming from my truck, there were no other vehicles around, and varied with my engine speed. What on a diesel would cause this "ignition" noise?
Location: Frozen Northern Minnesota, Darn Close To Where Perma-Frost Begins...
Check the antenna ground. Sometimes the surface under the antenna mounting (inside the fender) area becomes a little corroded (all zinc coated parts). Pull the antenna and wire brush all the parts and reassemble. Should kill the buzz.
JuzPlaneKrazy
07-20-2007 01:56 PM
Sixpack73
03-22-2007 11:55 AM
Oilburner04
09-26-2006 09:32 AM
