Radiator flush, question?
Old 08-29-2008 | 01:14 AM
ollie32's Avatar
Hi there,
I drained my rad the other day, was following instructions on some site which said to add 3 gallons of fluid then top the rest of the system up with water. Wish I had done my reseach and discovered that I should have mixed it 50/50 before hand. Going to get a gauge and test the solution, not sure where I stand. Think I am pretty close to 50/50. Gonna buy a tester tomorrow.
My question is,
During the last couple of day there seems to be a buring smell coming from the engine. It has never done this before, I am thinking it's either the fluid gasing off or the metal on the new thermostat heating up and changing it's properties. I have been keeping the overflow tank full, seems to be still sucking a bit of fluid back from time to time. Been keeping my eye on the temp, does not go above 90ish on the trucks guage and 186 or so on my commander module.
Just want to make sure it's happy, not over heating or any potential damage.
Thanks
Old 08-29-2008 | 02:37 PM
Pooter's Avatar
Did you use the right fluid?
G-05 HOAT coolant...(And I believe you're supposed to use distilled water with it too)
Old 08-29-2008 | 04:56 PM
mishkaya's Avatar
Originally Posted by ollie32
Hi there,
My question is,
Thanks
As far as I am concerned, that depends on whether you flushed the system or only drained it. When I flush the system, I use the amount of fluid necessary to achieve a 60/40 mix, and fill the rest with distilled water as that way I am sure I have the right proportions. If I just drain the system, then I just replenish with a 60/40 mix.
mishkaya
CACalomino
16
03-22-2010 06:35 PM
Sam Turner2
11-18-2008 10:17 AM
grantx5
01-05-2008 06:56 AM
dieselfan
11-10-2006 08:01 PM
LFD2037
11-08-2006 09:12 PM
Quick Reply: Radiator flush, question?
