Quicker warm-up in winter?
#33
Without discussing why you would need to plug in your truck or put a winter front on it in GA.......if you idle 10 mi and then drive 20 min and it's barely warming up, then your thermostat must be stuck open.
I've had my diesel in -20deg weather and after 30 min of just idling, it's up to temp.
#34
My truck will not come up to temp in 30 minutes of idling in PLUS 20 degree temps,even with high idle and cardboard,and the thermostat isn't faulty either. Once it's up to temp it will hold it at an idle, but it will not reach temp from cold while at idle. It's really strange how much these trucks differ for them all being pretty much the same.
#35
#36
The 3cyl high idle is a 2nd Gen VP44 thing, doesn't work on 3rd gens.. .3rd gens get the cruise control controlled fast idle. Since the OP has an 03 it may or may not work, it doesn't work on 99% of the 03's...
But otherwise the best is
1. Winter front, Mopar is best
2. Plug in.. 90 minutes for 25*+, 120 minutes for 10-25*, 0-10 2.5 hours, below 0, 3+ hours.. I have found that 90 minutes gets you about 60* over the ambient without the winterfront, it gets warmer with it.
3. Exhaust brake
4. Fast Idle, if you can't get the OE one to work there are aftermarket ones.
3. Exhaust brake
#37
I would be lost and cold with out my Mopar winter front. I will say it sure was nice to have it Monday night on our drive to and from the Twin cities when temps hit up to -15 below in some places!
#38
I didnt get one today, but looked at them on the net. I didnt realize they went under the hood behind the grill. I thought they mounted outside and covered the grill. May pick one up tomorrow
#40
Yeah, at first I didn't know if I liked that idea, but I really like it now that I have it... I like that it cover the intercooler because that provides heat to the intake air. Yesterday it was 27* on the way to work, with all 4 flaps closed my intake air was between 65* and 85*(without it the IAT would have been 35-40*). So you do have to be careful with all 4 flaps closed if your at fwy speeds and its about 25* or so out... but 3 flaps closed I have never had it get too hot of intake air temps. (towing is a different story, even will all 4 flaps open in 25* weather I couldn't tow at 65 without getting hot)....
mtb1982
55
01-20-2020 10:45 AM
