Quick easy question?????????????????
I have a 05 CTD 4X4 G56 dually.
I need to know how much oil the FRONT, REAR, diffs.
TRANSFER CASE, and G56 TRANS, holds.
I am going to Amsoil.
Thanks in advance
Thanks in advance
I am preparing for the same.
They tell me to get 7 quarts and that will cove the front and back diff no matter which rear end you have. The transfer case 2-3 quarts is what the dealer suggested.
Ask the Amsoil dealer
The guy I get my Amsoil from gave me a printout of every fluid that thing holds, type and quantity. Just ask the dealer you are getting your oil from and I bet they can do the same for you.
transfer case = 2 quarts = ATF+4
front diff = 3 quarts = synthetic 75-90
rear diff = 4 quarts = synthetic 75-90
g56 = 6 quarts = ATF+4
If you have an early build g56 and can not get 6 quarts in you have to take the shifter boot off to fill the rest. Some of the early build G56 transmissions had the fill hole in the wrong location.
Subliminal
04-27-2010 10:58 AM
04ctd
02-25-2009 07:13 AM
HorseHauler
04-26-2007 04:49 PM
HorseHauler
13
03-12-2006 11:48 AM
